wsoxfan2005
100 µW
- Joined
- Jan 21, 2014
- Messages
- 9
Hello,
I have an eMoto Ridge 2.0 ebike which I absolutely love. (No longer in production)
The bike has a 250W (350W peak) motor and a 37V 9ah battery.
I live near Tacoma, WA. and needless to say that the area is quite hilly. For the most part I find that 250W is enough and since I have a two speed control there are times that I ride in low. With that said, there are hills around here that I have a very hard time climbing. I really wish I had a little extra oomph to climb those hills.
I really can’t afford a new bike and on top of that I really like the bike I have so I am thinking of doing an upgrade to a 500W motor.
I found a rear wheel drive that is sold in the UK that can switch from 250W to 500W that comes with a 5 speed controller for a 36V battery pack. This set up would allow me to run the motor @ 250W most of the time and 500W when I need that little extra boost in power. I also really like the idea of a 5 speed controller and I found that I can buy the 5 speed controller by itself that is for a 36V battery.
It seems to me that I can accomplish the same thing with a 500W 5 speed controller. If I have a 500W motor and I run it at speed #2 I should be running @ 200W. Here is my first question, am I thinking correctly on this?
The other thing is that since I already have a fully built ebike with a throttle, speed sensor, brakes, and battery pack the only thing that I should need is a new rear wheel and controller that is as long as I get a 36V rear wheel and speed controller. This is my second question, am I right here?
My other concern is my bike is fairly quiet and I am looking for a motor that is quiet also.
Again, I am not looking to break the speed of sound. I pedal in assist mode 99.99% of the time. I am more concerned about battery life and distance then speed. If I can conquer some of these hills around here that would be awesome.
Anyways, I am a newbie at this and I appreciate any input that you can offer.
Thank you in advance.
Pete
Pete
