John in CR
100 TW
henrynz said:Quick update: Mark from Enertrac saw one of my video's and thought there was a possibility that the magnet ring inside the hub motor was spinning. He offered to fix it free of charge. To check this, I pulled off one of the side covers and marked the magnet ring against the hub body with a marker. I reassembled the hub motor, took it for a test ride until it started cutting out/jerking again. I then disassembled it again. The mark had not moved so I believe I've ruled out this as a problem. It has furthered my conviction that the controller is at fault.
I'm on the wait list for a Nucular controller - around 4 months. Will update when I make any progress here.
Just to be sure, I think you should run that test again, but mark on the magnets too to make sure their adhesive didn't come loose and allow all of the magnets to slide within the magnet retaining ring. That is a somewhat common failure.
