So, in this thread, I want to discuss EROI or Energy Return on Investment. In classical financial investment, there's this concept called ROI. Basically, how much money do you make from investing a certain amount of money? A ROI of 100% is good because you just invested some amount of money and just doubled it. If you kept doing that over and over again, you'd be rich in no time!
The same thing can be done with oil. "In the beginning", conventional oil had an EROI of 20 to 1. That is, you invested 1 unit of energy and you got back 20 units of energy from oil. Essentially, FREE ENERGY! But, as conventional sources are exhausted and unconventional sources are tapped, the EROI is going down. I've heard it speculated that the EROI of the tar sands and such is 4 to 1, which is good, but nowhere near the return on investment from the bonanza of the "hay days". What you don't want is to get more energy than you put in, that is a ratio less than 1 to 1, because then you're losing energy and it's essentially not worth it unless you *need* oil for something other than energy.
So, what are the ROI of other technologies? If you took a certain amount of energy to create a solar cell, extracted energy from the sunlight using it, and over its lifetime you got back so much energy, how many more solar cells could be created from that energy? Is it 2 to 1? 20 to 1? Estimates? It'd be encouraging if it were positive thus energy growth could be sustained from solar cells, despite that it might take a long time to reach the current energy extraction rates of oil at present. It might not, however, depending if its EROI is high enough. What's the EROI of wind-mills and other technologies?
