hjoore
Hi guys,
I just completed my first friction bike stealthy prototype 1.
I use a Turnigy Aerodrive 63-54 motor, with a cheap HobbyKing SS 190/200 A brushless ESC and a 5S 8000mAh Zippy LiPo.
At first I had some problems with the ESC slipping electrically and screeching a lot, due to wrong standard settings.
You can download the Instruction manual for all those SUPPO Speed controllers here:
http://www.leaderhobby.com/img/menu/skywingESC50A-200A.pdf
After going through most of the options, here is my final setup:
Option 1: Cell type - auto * (*=factory setting)
Option 2: Throttle setting - 2.1 Auto Throttle Range *, and 2.4 Soft Acc(eleration)
Option 3: Brake Setting - 3.2 Soft Brake *
Option 4: Direction and Cutoff Type- 4.1: Clockwise Rotation*, and 4.4: Hard Cutoff ( just to make sure unbalanced cells don't get decharged too far)
These are the most important ones:
Option 5: Timing Mode Setting - 5.3 15deg For 10-14 Pole Outrunner Motors
Option 6: Pulse Width Modulation (PWM) Setting - 6.2 16KHz For most outrunner motors
With these settings, my ESC doesn't run hot at all at 40km/h at 650 Watt,
but most importanty: it never slipped or screeched after these settings were used!! The motor now makes mini burnouts on the tire if I really push it at low speeds, thats power.
Share your own settings and experience with this ESC. For $29,99 its a steal!!
On to prototype 2! Fully aluminum this time.
