francuscus
New here
Hello, community. I’ve been getting involved in the topic of BMS (Battery Management Systems) and their role in determining the state of charge (SoC) of LFP-type batteries. Perhaps someone here has experience with how to use a BMS for testing batteries. I’ve been conducting charge and discharge experiments and HPPC tests (pulse tests to obtain the dynamic properties of the battery). So far, I’ve done this without a BMS.
What I want to do now is perform the same experiments using a BMS to monitor my battery pack and see what SoC estimate it provides during these experiments.
My question is about how to connect the BMS if I want to obtain voltage and SoC data through it. I’m attaching an image of my setup. Currently, I have a set of batteries connected to a programmable power supply and, in parallel, to an electronic load. This allows me to charge and discharge the batteries by turning the power supply and electronic load on and off as needed. However, I’m unsure where the BMS should be connected. Should it be connected in parallel with the batteries, the power supply, and the load? Or should it be connected in series with the batteries?
I’ve seen diagrams of JBD BMS units showing a -B terminal that should be connected to the overall negative terminal of the batteries and a -C terminal that should go to the negative terminal of the charger. From this, I understand that the BMS should be connected in series with the battery pack and the charger. But my question about this is: will the current flow through the BMS? Wouldn’t this damage the BMS if I’m charging the batteries with a very high current?
