Nico
I recently bought a second hand eZee kit, intended for a Yuba Mundo, to put on my xtracycle. The battery is 37V 14Ah, and according to the seller and the Cycle Analyst that came with it, it had 11 cycles.
One of my first tests, the battery gave up really quickly. It suddenly turned off and wouldn't come back on. I charged it overnight (measured 41.8V), put it on the bike and it worked normally. I thought maybe the hills around here were too much, so I set the CA to a 16A limit and was careful to keep it under 12ish amps on climbs.
Today, after two rides totaling about 15 miles but less than 2Ah, the battery gave up again on a hill. I was pulling about 10-12 amps, don't remember the voltage. As soon as I got home I measured about 11V
and slowly climbing. I let it sit for a while and it stabilized at 37ish V. I tried it on the bike again, and the CA flashed on and quickly off. I measured the battery and got 9.5V
, again, climbing slowly. Once it stabilized again I put it on the charger and there it is now.
I am new to electric bikes so I'm trying to make sense of this. It doesn't seem normal, but how bad is it? Could it be just an unbalanced pack or is it a sign of dead cells? Also, even though I set the CA to a 16A limit, it recorded peaks of well over 20. Is this normal?
