Faster throttle response means probably higher peak battery currents.
With a battery consisting of 3 different packs and 3 bms , how can you tell which ones does cuts first? If the first ones has shut off, the others will immediately follow.
I would set max battery current to 150-200A, 300A or more seems way to be to much for your setup.
If you have to lower your low voltage cut off to get more battery current, your voltage sag is to high.
