Farfle
cwah said:Woaaa
Will you be inside or remote controlled?
How long can u fly?
It is a piloted aircraft, so ill be flying it. As far as run time goes, I am hoping for an hour plus ~15 mins of margin.
cwah said:Woaaa
How long can u fly?
MrDude_1 said:I really wish all the pictures on this thread were attached to the thread. Now they're just ads for hosting service.![]()
amberwolf said:Personally, if I had any data hosted on a site that did something like that, I'd download and then remove the entire account and data. Or maybe leave one little bit that says something like "hey, if y'all are looking for my stuff, this provider did (whatever it did) and caused me to take my stuff elsewhere, over here (wherever it now is).
Then I'd directly attach all the images for stuff on this forum into the spots in threads the old PB links used to occupy.That way it'd be saved locally, backed up when the forum is, and viewable by anyone that can access the forum itself.
etard said:I just wish I could see what everybody is so impressed with.
ES itself is pretty stable.Farfle said:there are no real stable image hosting sites at the moment.
fechter said:It's alive!
...well, sort of. Real test will be with the prop installed. Could get pretty windy inside the garage. I've seen them testing planes after an engine overhaul on the ground with some kind of big load cell that measures the thrust.
Is the Cycle Analyst FAA approved aircraft instrumentation? :wink:
craneplaneguy said:That appears to be an adjustable pitch prop? So electric motor or no you still have to do the black magic of finding the best blade angle for that motor's torque.
And it WON't be the max thrust (as measured by a scale) when tested on the ground, unless you like driving a car around in first gear, same deal!
Looking good, love that fuselage and can't wait to see the wings on it. FWIW: I have a 3 bladed prop hanging on the shop wall (along with many others, all with a story behind them, been flying powered for 35 years) that was on my brand new Kitfox back in '88. My first taildragger, I was out doing some taxi tests before flying it for the first time, and got distracted by a brake issue. So while I had my head down looking at my feet I revved it up to load up the brakes and being a total newbie forgot to hold the stick back.....and up on the nose I wentProceed cautiously, you don't know what you don't know, but it looks like you are doing a great job so far.
craneplaneguy said:So while I had my head down looking at my feet I revved it up to load up the brakes and being a total newbie forgot to hold the stick back.....and up on the nose I went![]()
