What input power levels are you requiring, 120v or 240v?
Do you want stationary or portable charger?
Any specific size you are looking for?
Price is no object obviously in your case
You can series some Meanwells, perhaps even the RSP series.
https://www.meanwellusa.com/upload/pdf/RSP-2400/RSP-2400-spec.pdf
Active current sharing up to 7200W (2+1)
43 ~ 56V @ 50a
https://www.digikey.com/en/products/detail/mean-well-usa-inc/RSP-2400-48/7706321
72v is 20s is 84v fresh off the charger, so two in series is 86v so your good to go there.
Even a 3000w rsp model, looks interesting
https://www.meanwell.com/productSearch.aspx
https://www.meanwell.com/webapp/product/search.aspx?prod=RSP-3000
43 ~ 56V @ 62.5a and 20A/180VAC 16A/230VAC
- Output voltage programmable
- Active current sharing up to 9000W (2+1)
- Optional conformal coating
Complete list
https://www.meanwell.com/productSeries.aspx?i=22&c=6#tag-6-22
Other options
https://www.meanwell.com/webapp/product/search.aspx?prod=NPP-1700
https://www.meanwell.com/webapp/product/search.aspx?prod=DBR-3200
ELTEK 1.8kW flatpack S
https://endless-sphere.com/forums/viewtopic.php?f=14&t=71139&hilit=charger
EMC-2000
https://endless-sphere.com/forums/viewtopic.php?f=14&t=29096&hilit=charger#p419529
6600w
https://endless-sphere.com/forums/viewtopic.php?f=14&t=52560&hilit=charger
Voltage output: 74.0V ( adjustable from 29 to 76.8VDC)
Current output: 91A (0.75C charging rate)
I have heard of people installing DIY EV charging capabilities for commercial EV chargers on their ebikes and emotorbikes.
Might be something to look into.
Albie72 said:
Looking for a fast charger to charge a 72v 80ah lithum
