madmax
As usual during long evenings on winter Nanga Parbat (www.nangadream.blogspot.com) some ideas came to me... This time an ebike! as a part of energy revolution which already started.
I spend my whole past cycling so picking a bike was the easiest part (bike will be for commuting 16km one way / and taking to train ). Dahon Jetstream older model arrived last week...
Getting informations mostly from that forum I have picked those parts:
(from ebikes.ca )
- Nine Continental Hub Motor 2806 in 20 inch wheel
- Cycle analist V3 direct plug in
- TTL->USB cable
- eZee ebrake Cutoff Lever
- Thermistor
(From Lyen.com)
- 12 FET 4110 MOSFET Extreme Modder Controller LYEN Edition
- torque arm
- Cycle Analyst connector, external USB-TTL connector for USB-TTL programming adapter, regenerative braking enable/disable jumper
- USB-TTL programming adapter
- Three Speed Switch
- Thumb Throttle
(from bmsbattery.com)
- 24 S BMS ! http://www.bmsbattery.com/bmspcm/378-17s26s-24a-max-discharge-current-bms.html
- 25 Headway 38120S http://www.bmsbattery.com/lifepo4-cell/118-headway-38120s-lifepo4-battery-cell.html + holder and connectors
- charger 400W - http://www.bmsbattery.com/alloy-she...po4li-ionlead-acid-battery-ebike-charger.html
(from thun.de)
- bottom bracket torque sensor X-CELL RT 120K/116 Digital output signal
appreciate any comments on that set up.
I will work to mount batteries on the frame - will be posting that later.
thanks
(from ebikes.ca )
- TTL->USB cable
- Thermistor
(From Lyen.com)
- torque arm
- Thumb Throttle
(from thun.de)
thanks
