Fuzzy Head
Hello everybody.
I have one of these:
http://www.google.co.uk/search?hl=en&q=pdq+power+trike&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41524429,d.d2k&biw=1280&bih=868&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi&ei=xFoFUfPWFYGV0QX71IGYCQ
Fundamentally it is a wheelchair with an attachment for the front part of a BMX bike with a hub motor. From a Design/Engineering point of view it is quite an interesting machine and although quite old now it is very helpful in allowing me to get around until I fully recover, it also suited my needs better than anything else I could find at the time of purchase. Currently it has lead acid batteries which weigh a tonne and don't offer much range (partly due to what I think is called the Peukert Effect). Seeing as I have a strong interest in how things work I have decided to build a battery pack rather than buying a pre built one.
I believe the motor is a 150w DC brushed, direct drive, hub motor that it designed to run from 36v. Although not very powerful, if this project goes well I intend to upgrade the motor and control box.
I would like to start by making a smaller battery pack with the intention of it being a backup battery pack in case the first fails which will be put under the seat. Although the Trike is much like an ebike I can not just cycle the rest of the way if something goes wrong or run out of power, so I need to make sure I get quality reliable parts.
Although I have done a good amount of research I am no expert with no practical experience with LIFePo4's (the chemistry my research has lead me to believe is the best choice with current technology) therefore I am seeking advise before I make a purchase and assemble the thing.
Some possible part choices:
http://www.bmsbattery.com/lifepo4-cell/118-headway-38120s-lifepo4-battery-cell.html x12
http://www.bmsbattery.com/bmspcm/322-17s26s-24a-max-discharge-current-bms.html
http://www.bmsbattery.com/alloy-shell/25-alloy-shell-240w-lifepo4li-ionlead-acid-battery-ebike-charger.html
Has anybody had any experiences with the company BMSbattery? I am not sure what sites are best for parts. I live in England. The above site has an option for GBP but the price estimates seem vague.
What do you think of my part selection? Take into consideration that these parts must be very reliable and I can not risk them bursting into flames.
Would it be worth my while getting a BMS with a much higher discharge current capability than I am likely to ever need?
Is the charger I selected appropriate? It is about 0.5c I would rather extend cycle life than reduce charge times.
Apart from battery connectors what other parts will I likely need that I may have overlooked?
Thank you
Thank you
