So I thought I should share my latest bike build, especially as I've been a long time stalker of various threads without actually contributing very much, apologies and thank yous all round.
I actually pretty well finished it last year a part from a bit of fine tuning of the gear ratios. I took a fair few photos along the way thinking that I may at some point actually get my s*it together and post something. I used the belt sprocket from lightning rods and also the jack shaft and go cart sprocket, oh and the motor with the converted shaft and belt output sprocket, can't remember the motor output to large belt sproket reduction. On the other side of the jack shaft though I think it's a 12 tooth down to a 68 tooth on the go cart chain (518 pitch maybe?) Then the bike side is a 48 T out to a 13t on the rohloff in the back wheel. It's using 3x Turnigy flight max 22 volt packs in series, so 3s 1p. Although the cell on one of them just puffed up and so I think I'm going to get 100 x 18650 cells and go 20s 5p. Would love any advice on which cells are the best to go for. It's a Lyen controller and CA (version 3 i think). Just been uploading pics, think I may have hit the limit that I can load. It show's the fettling required to the swing arm to get the 24 x 4 inch tyres to fit. Can't really think what else to add a part from it being a real blast to ride tops out around 40mph and pedals very comfortably pretty well right through the gear range, I can't recommend the rohloffs highly enough. Well that's it, any comments or questions welcome
