BatteryMan
- Joined
- Oct 10, 2016
- Messages
- 19
For those of you that own the Mongoose Hitch/Dolomite/Brutus, etc. what kinds of tires (brand and model) and tubes (name and size) are you guys running? From what I understand you can shave off 7 pounds just by switching the tires and tubes! I'm looking to do just that and would like to get a 4 season tire as I don't want to switch tires every winter.
Here are three tires that I found, which one would you buy?
Origin8 Devist-8er UL Tire
https://www.amazon.com/dp/B007HOJBDE/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=3F454X6EASA5M&coliid=IER03KFDBNELC
Kenda Juggernaut Sport K1151 Wire Bead Fat Bicycle Tire
https://www.amazon.com/dp/B00QRJH3ZS/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3F454X6EASA5M&coliid=I21D703TFWQBF&psc=1
Origin8 Supercell Wire Bead Fat Bike Tire
https://www.amazon.com/dp/B012EIXCWI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3F454X6EASA5M&coliid=I1893M1HCGE8UM
As far as tubes, this is the one I found but would like to know what other people are running:
Sunlite Standard Schrader Valve Tube 26 x 2.75"-3.00"
https://www.amazon.com/dp/B000AO9OJO/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3F454X6EASA5M&coliid=I3BL7SI6Q6J8NL&psc=1
I would greatly appreciate any advice.
EDIT: Anyone here run a moped rim or tire on a fat bike? 26 x 4"?
