ChoopaK, I may be going out on a limb here, but regarding heat & high voltage with MAC, the fact you were running a 6-turn, and a non-EM3EV controller, are both red flags to me. (And was yours a first-gen or 2nd gen?) So yes, I wouldn't do that. But I will be getting the 12-turn, the slowest wind they make, and a properly fast controller. I also ride gently, normally. And plan to probably experiment with oil cooling either way. The beauty is, I can always use 48V if I decide 72V is too much, or if I'm doing a shorter ride. EM3EV does include an up-to 72V controller option in his kit, and I have found him to be conservative, or at least careful about matching kit items. Of all the things he warned me about, the 72V wasn't one of them, LOL. But I will pay attention.
Lutefisk: I'm honored to have your first post in my thread! Welcome to the board! I'm pretty new here myself
Don't apologize for length, drop it on me.
Well, EM3EV sells only 2 motors: MAC and the BBS02. That tells me something right there. So, the BBS02 is #2 for me right now. I keep going back and forth. I just don't think it would be as pleasant of an experience... This is just for pleasure, not a commute, which affects my choices. Using the gears is a mixed blessing. First, yeah I wouldn't be able to do this with a fatbike at all. Then, I'd have to be shifting gears all the time. See, I do a lot of stopping "to smell the roses". Think sightseeing. That's a lot of gear shifting and distraction while I want to focus on the experience (not sure, but that's what I'm thinking). On a commuter, that extra control is probably desirable, and you're already focused.
BBS02 is only medium power, so reliant on gear selection. Mostly though, I think current mid-drive solutions, and the BBS02 specifically, are works in progress, whereas the MAC, especially from EM3EV, is strongly refined. I expect the BBS02 to be obsoleted quickly. Following Neptronix's experience, the built-in controller seems to be crap, it needs serious tweaking right out of the box (I don't fear the programming whatsoever, just a statement on factory quality), and there are other issues I'll leave for those threads. I am fascinated by its quiet-ness, the freedom to change wheels, and improved hill climbing ability. I find I just don't "want" it enough. I'm sure if I could ride each, I'd know right away, but barring that, sometimes you just have to make the best decision you can, and I find even with research, I often am wrong. That's demoralizing to hear you kept running into brick walls w/your Moonlander. Just sucks
Some clarifications, lutefisk: I never mentioned rewiring the MAC. 20-25mph is the fastest I think I'd "ever" want to go under motor power, and then only in ideal conditions (no one else on the road, good surface, feeling safe, or emergency). On unpaved roads, and just commonly anyway, I'd probably be doing only 8-13mph. I'm not in a hurry to get anywhere. I just don't want the damned bike bogging down on steep hills without momentum (is that too much to ask? It seems so). Golf ball sized concrete stones are not common, but they are around. Most of them rocks are under an inch. Still, dangerous and not fun. Safety is my first priority. Then fun. Leisure fun, not sport. Hence how the fat bike fits... I think. (Never having ridden one). Would you agree on that?
I really have no interest in a rear suspension, yet. I've done a ton of (mostly road) riding in my youth, and never yearned for a rear suspension. I did yearn for a front suspension before they even existed, though. BikesDirect is going to be releasing a somewhat cheaper fat bike with front suspension in coming months (no price announced). I might hold off till then. I've seen Neptronix and WesNewell talk about how how much of an upgrade they thought rear suspension was.. I respect them, but for me, I'm not seeing it. I'm not sure what a hub motor actually does to the ride, though? MAC is light, only about 8 pounds IIRC, about the same as a light DD, I think. What rear suspension does to the available battery space and overall complexity doesn't help either. At this point, I'd still take wider tires over a rear suspension. I could always get a suspension seat post, though (and probably will). But a normal mountain bike with front suspension is still a consideration. I am also concerned that the front suspensions on cheap mountain bikes will basically be crap.
Here's what you wrote that really intrigued me:
Regarding it's climbing ability--if you can stay on the bike, it can climb it.
Please, please, elaborate! Details! What have you tried so far? Care to share your and your bike's weight?
That kind of contradicts the little I've been able to find online. The closest I could get to info on this specific matter was 1Boris, who is somewhat heavy. He actually has both a MAC (10T, I think) and BBS02. He did a steep (off-road) hill test, and actually said that both motors eventually stalled, but the MAC won (went farther before stalling, and more confidently). That did it for me. I almost want to pay him a tip!
So then, someone chimed in and told him he had the wrong front sprocket size or something, that he needed a smaller one. Whatever. I haven't even seen such a thing for sale? From what I know, the BBS02 comes with a replacement crank assembly, including front sprocket (or whatever it's called), and that's it?
A separate video I saw was a brief, poorly made video by one of the pro outfitters (hi-powercycles, I think), of 2 bikes going up a steep but only ~5-foot long incline, but from almost a standstill. Their BBS02 model "won", but clearly could not have kept up at that incline--it was nearly stalled at the top. By comparison, their Direct Drive model at 2000 watts (with normal wheels) was hopeless without momentum/RPM. Disappointing on both accounts.
The way I see it, if you're limiting a competition to the same amount of current, the BBS02 at 750 watts will win. But that's not how life works. The MAC can use much more wattage... not as much as DD, but a lot. So while it's less efficient during those times, for shorter distances at least, it also might be able to do things a BBS02 can't--I THINK (I don't know). Also, the belief that a BBS02 can't overheat or never gets hot, and can climb mountains "all day long" seems mythical too. I see the MAC as kind of a compromise between DD and mid-drive, all of which are appealing to me for differing reasons. My biggest concern for the MAC, outside axle size, is actually noise, believe it or not. I KNOW it can more than suit my local 'sightseeing'. Can it go up a mountain, though? That remains to be seen.
I will admit Neptronix bought the BBS02 while having a MAC, because he moved to a very hilly area. From reading his thread, the jury is still out on whether he likes it more than his MAC, though.
I'm thinking about doing a 24-incher for the rear no matter what I end up with, but that too adds extra complexity, due to rarity of parts. This is where the BBS02 would make life easier. If you buy and lace up a special rim for a hub motor, you're basically stuck with it. Harder to experiment. I could get it on a 24-inch rim from EM3EV, and see if it's fast enough, and handles okay.. If so, commit to a nice wide 24-inch rim, as 24 is only offered by EM3EV in 24mm. If handling is weird or I prefer more speed, I could switch to 26. :|
