harrisonpatm
- Joined
- Aug 8, 2022
- Messages
- 843
I was assisting a client in fixing his ebike. Long story short, the new 48v nominal Li-ion battery he purchased has something wrong with it. It has a switch on the side to turn the voltage on and off. When connecting the + and - to the controller, and turning the battery switch on, a small spark can be seen on the positive connection, a click can be heard from within the battery case (not the controller), and the voltage is disabled. Turning the battery off, rechecking connections, turn it back on, same thing. At one point a 10A fuse was put in line to the controller, which blew. This all happened without the motor phase, hall, or throttle connected. This happened using 3 different controllers. When the battery was swapped with a different 48v nominal battery, everything worked as expected: controller powered on, motor spun up, ect.
So, it seems like the "new" battery has something wrong with it. Likely the internal BMS. The fix is already done: the client will order a different battery, the ebike works as it should. My question is, why is this happening in the first place, to a newly purchased battery? It seems as though when simply connecting to the + and - of a motor controller (two different controllers), the battery immediately attempts to deliver a huge rush of current, which pops a fuse and causes the BMS to trip an internal overcurrent protection. Why? I don't believe it to be the controller's fault, as the same behavior happened with two different controllers, and nothing else was connected to the controllers except the battery. A different battery powers everything appropriately, with no sparks. What would cause this battery to exhibit this behavior?
I asked because the client will attempt to return the battery from where he got it. If he can't, I wonder if it's something that I can fix for him. Apologies: I don't have the battery with me currently, so I don't actually know the brand or model to look up. I was simply asking if this was a generic issue that someone has seen before.
Thanks!
Thanks!
