Alan B
The industry has a number of development boards and software kits for Field Oriented BLDC motor Control. Here is one from Texas Instruments:
http://www.ti.com/tool/dk-lm4f-drv8312
Some Specs:
80 mhz 32 bit floating point Cortex M4 ARM processor on 64 pin DIMM plug in board
256kb flash
32k ram
dual canbus
8 serial ports
6 i2c ports
two banks of 1 megasample/second 12 bit ADCs with 12 channels
two watchdog timers
dual banks of PWM motor controllers
dual quadrature decoders
plus more
This starter set includes hardware and software to get started quickly, even a small motor and power supply for less than the price of a 24 FET controller. The processor is on a small board that can be plugged into a custom power stage and run on your ebike, with all the small pitch electronics done. These ARM boards are $49 so not out of reason for using in a controller.
There are other similar starter sets out there for various processors, such as the PIC unit that Bertie is experimenting with in another thread.
Anyone else tried these or similar boards? What is the best one to start with? Any interest in making a power board to take one of these plug in processors?
Some Specs:
256kb flash
32k ram
dual canbus
8 serial ports
6 i2c ports
two watchdog timers
plus more
