rg12 said:
I see, so if a cell goes bad making the nickel touching the ring to go super hot for some reason after a failure, then how much heat can it tolerate? it's just paper after all, there is a reason why we use kapton and not regular tape...
The ring is mostly to prevent shorts where something wears through the insulation on the top of the cell (nickel strip, balance wire, battery casing etc). It will also give you some protection against an over-heating nickel strip, but hopefully you'll manage to design against that happening. A fire proof ring (maybe some kind of fibreglass) would theoretically be better, but I don't think anyone goes to this length.
