tgice
Hi guys, I'm new to the community and am looking to build my first ebike for a 7 mile one way commute to work.
I'd like to be able to get a decent amount of exercise during the ride, but not so much that I'm heavily winded (or sweaty) when I arrive, so I'd like to be able to reasonably assist during the ride. I'd also like to possibly be able to get up to 25-30 mph during parts of the ride to make it nice and quick.
Desired max speed on level ground: 28mph
Desired max range at what cruising speed: 10 miles at 25mph
Preferred bike wheel size, or wheel size of bike you want to convert: 26", but flexible
Brake type of motor wheel: V brake on rear (motor), maybe disc on front (no motor)
I'm 6'2" and 155 lbs, and would normally not be carrying much of any extra weight with me.
I've read about how MTBs are generally best for a sturdier build in general, and you prefer steel framed bikes. The only one I currently have that could be a donor is an 20+ year old Huffy 26" 18 speed that's missing the front derailleur (it broke years ago and I just removed it, leave it on the middle of 3 gears) with some crappy caliper breaks that work, but I probably wouldn't want to rely on at speed. Naturally the cheapest option would be to start with that and later upgrade to a new bike, but I'm leaning towards buying a new cheap (Walmart) mountain bike, unless you guys can talk me out of it.
Most mountain bikes (even cheap Walmart ones) seem to have aluminum frames, even in the $125 - 150 range, e.g.:
http://www.walmart.com/ip/26-Genesis-V2100-Mountain-Bike-Dual-Suspension-Men-s-Bike/22899847
here's one w/ only front suspension, but apparently an all steel frame for the same price:
http://www.walmart.com/ip/26-Schwinn-Sidewinder-Men-s-Mountain-Bike-Matte-Black-Green/26999374
I think I'd prefer the paddle shifters on the first one to the Shimano Revos on the second (which also are more common the Walmart bikes).
In general it sounds like a *rear* wheel hub motor kit at 48V and 1000W would be the best bet for me. I'd get a Lithium pack of some sort, that initially I'd probably configure to carry in a backpack (save a bit on other mounting options up front, and might want to go indefinitely with it like that anyway, so it's easy to carry inside at the office and back at home to charge inside).
I think I'd prefer to have at least a front wheel disc brake to help with higher speed stopping, and in case I end up riding in rainy or snowy conditions (which is possible), even if these cheaper bikes have crappier setups, I suppose I could always upgrade them later, but at least I'd know the forks are wide enough to accommodate the disc, etc., right? Or should I go instead for the all steel Schwinn (or similar) with no disc brake, figuring I could just upgrade to a new wheel w/ disc and add the other part of a disc brake to the fork later?
I'm kind of leaning towards a Magic Pie (or Smart Pie) kit in the $400-450 range (shipped) vs the super cheap eBay kits in the $250 range, just thinking that maybe the quality is better there and I'd get at least some support if I have a problem, and it'd be more likely to last longer. I like the idea of an internal controller too.
Well, I think that covers most of the details I've been kicking around for awhile in my head in advance of putting out my first post. Let me know if I've missed something important.
I'd appreciate hearing general advice on a first kit where I'm trying to stay pretty cheap but at the same time be able to get built and on the road ASAP with something that could last me at least a 1 - 2 years so I can get a feel for how useful I'll find ebiking, for commuting primarily.
Thanks.
Thanks.
