Hi all,
I've been reading through the forum for days now and wanted to get your input on how best to build a reasonably priced ebike that's durable enough to play bike polo. I had to stop playing bike polo a few years ago due to some health issues that limits my cardio output. Performance requirements are as follows: We play 4 vs 4 on a grass soccer field and use pairs of traffic cones for goals. Our style of play typically requires a sprint front end to end (maybe top speed of 17MPH) followed by hard braking and slow, intricate bike handling in front of the opponents goal. Lots of stop/starts with balancing in between. Someone once measured about 12 miles of travel on a typical game day (we play multiple games). I can pedal fairly hard as long as it doesn't require sustained effort. Almost everyone uses single speed hard tail mountain bikes to play......keeps our bikes simple to repair/less likely to break down. I use a single rear mechanical disc brake on my steel Surly 1x1 frame. I can't remember the teeth count on my front chainring and rear cog. Will post later.
Based on what I've read on the forum, I've made the following assumptions:
1. Rear Direct drive is probably best due to simplicity/durability even though I'll lose torque at startup and true freewheeling when not pedaling
2. I'd like for the rear hub motor to roll as freely as possible and be compatible with rear disc brakes
3. I've never ridden an ebike so I have no idea how well PAS or torque assist works. Since I'm riding with my right hand on the handlebar (mallet in the other hand) it would be nice to only have that hand worry about braking only i.e. no throttle but I'm not sure if that's realistic. Maybe a PAS system with throttle override for sprints?
4. I think a bottle battery (or frame mounted battery as low as possible) would help with bike balance vs a rack mounted battery.
5. I've been looking at Dillinger conversion kits but am willing to buy individual components and piece together a better solution if that's possible. I did this for my electric skateboard which uses two 5S lipo batteries from hobbyking and a controller/motor from Alien Drive/Power systems.
6. Willing to spend up to $1,000 USD
Would appreciate any and all input.
Thanks!
Thanks!
