Hello, everyone, I am looking to convert my bicycle into an e-bike, I've made some research and am wondering if I can get some advice from someone with more experience on the field.
My bicycle is a old, 28 inch wheels, kalkhoff, I don’t know the specifics but you can see the pictures attached, I will probably install a disk brake in the front wheel (will be using a rear hubmotor with rim brake on it) and some dropouts in the back to improve safety.
I use it as my primary transport in Lisbon (the 7 hills city). I want to add a pedal assisted hub motor to climb easier, spend less energy and ride faster. I plan also to make longer trips from 50 to 100 km, (or 30 to 60 miles) in 1 charge.
Basically I want an ebike where I can reach and maintain a speed of 40 km/h (25 mph) on flat ground while pedaling, and get a good help when climbing. Once I succeed I will convert my wife’s bicycle too, and she should maintain the same speed.
I see that the prices have a wide range, either for the kits or the parts individually.
I heard good things about the MagicPie3 Hub motor:
https://bmsbattery.com/ebike-kit/429-magicpie3-sine-wave-rear-driving-ebike-hub-motor-ebike-kit.html
But also some bad things about the controller (they even send you an extra one..)
The price seems cheap, and it is easy to install, and I am not sure that it can be used with PAS (Pedal assist).
I see the rated RPM of the motor nowhere, so I don’t know how to calculate my actual top speed, it has 54 poles thought, If I knew the frequency I would get the rpms I guess.
This battery also from bms, seems a good fit for what I am looking for since it has around 1kwh.
https://bmsbattery.com/ebike-battery/161-48v20ah-38120-lifepo4-battery-32-cells-2p16s-ebike-battery-pack-battery.html?search_query=38120+&results=14
Any advice?
Despite being a first timer on ebike attempts, I have big plans, including being able to charge my bicycle with solar panels. On a trip I would pedal a maximum of 4 hours per day and take advantage of the sunny hours to charge the batteries for the next day. I wonder on how the weight increase in cargo will impact my top speed and battery range.
Thanks in advance, Claudio.
Any advice?
