Hi Guys, after some time lurking it is finally time for my first build! Hope to get some good advice from more experienced builders, so here goes: (Sorry for the wall of text, but I just want to provide as much info as possible)
The Basics
Bike is a rear wheel drive full recumbent, steel frame, no suspension. Currently setup with V-Brakes, but that might change.
Front wheel 20", rear wheel 26". Drive train is a standard 2x 8 Shimano setup.
Desired max speed on level ground: 40 Km/h, or a little higher (with significant rider effort, please see below)
(PS. I know that 25Km/h is the legal max. in the EU. But where's the fun in that?)
Desired max range: No max, but an absolute minimum of 40 Km range.
Preferred bike wheel size: Could be front (20") or rear (26")
Brake type of motor wheel. Currently V-brake. Will probably upgrade to Disc Front and rear.
Rider weight: 75Kg
Terrain: 100% flat, no hills whatsoever. (Location: Belgium)
Extra: Looks are not important, it's all about functionality. Stealth is not a concern.
Budget: Somewhere around 500€-600€ for a complete kit, if possible. Otherwise I will have to wait & save.
Builder skill: Pretty good. I do all my own maintenance and have built up a few bikes. Lacing a wheel wouldn't be an issue. But I have never touched anything e-bike'ish.
Intended use:
I commute twice a week to work, about 35Km each way. Currently I have a road bike (not an e-bike) and this takes me about 1h20 min. Terrain is fully flat with long stretches of open road with smooth road surfaces, about 20% is through urban area with some traffic lights. On the open roads, I can maintain 30Km/h quite happily, but I want to go faster than my legs allow 8)
I am looking to bring the time down to about 1h, while still getting my bike exercise. So I am switching to my recumbent which I want to electrify. I would need the motor to give me the final "push" to go from a top speed of 30Km/h (human powered) to 40 Km/h. What I don't need is a setup that does all the work for me, I just need some extra support for more speed. I find it quite hard to decide what type of motor/kit I need, as most high speed setups seem to assume you just sit on the bike and let the motor do all the work. Charging the battery during the day is possible.
What I came up with so far:
- Probably need a 48V Direct Drive motor and battery.
- Wattage is big factor. I read many people just putting in a 1000W motor, but that might be way too much since I will be doing most of the work?
- Since the motor is just for extra assistance, perhaps a smaller battery would suffice?
- From a weight distribution point of view it would be nice to have front wheel motor. Not sure if that is feasible in a 20" wheel, because it needs to have a much higher RPM?
- I have played extensively with the motor simulator, however without a good feel for the division of effort between me and the motor, it is hard to get useful data from it.
Any advice would be greatly appreciated!
The Basics
Rider weight: 75Kg
Intended use:
