The current draw from the battery will only be high on high duty cycles, so when going slowly you can have high torque and high motor current without drawing much from the battery since the motor inductance, input capacitors and PWM work like a switched mode power converter. For this to be safe you need and ESC with current control and/or current limiting. If the ESC does not measure and care about the current, you can get very high battery and motor currents when giving full throttle on low speed with hub motors and high battery voltage.
For the VESC you can configure different current limits for the motor and battery. You can for example set the motor current limit to 80A and battery current to 30A, which should work nicely with dual motors on a space cell. The motor current in each motor will then be able to reach 80A until you have reached 3/8 of the full speed. After that, the motor current will be more and more limited the faster you go.
