Been a while, but I've got some updates to share. I found a home for the controller. I will mount it in the subframe. It fits nicely and can get decent airflow if I mount a heat sink on it. The only down side is that the motor phase wire will not reach it so I plan to make a small junction box. I know it's not optimal, but the overall cable lengths won't be that much longer. I thought about mounting it under the batteries but it reduces lean angle clearance and mounting is tricky. Also in a crash it is less protected
Here are some photos.
I started charging the modules one by one with a lab power supply. For now that's my method until I decide on a charger. I charged each cell to 3.8V. The idea is to keep them around nominal voltage while I setup the Sevcon and configure the motor.
Then I assembled my two battery packs. The first one is 9 modules and will be mounted in the main area of the frame where the engine used to be. The second one has 5 modules and will be mounted on top of the steel tube frame and will be inside the perimeter of the original Buell frame. So overall I like that everything will be well protected.
Saftey first! :wink:
Next I took the stock wire harness from the Buell and tore it apart to get some free wires out of it.
I ordered a bunch of connectors, terminals, etc from Mouser to wire up everything and start the configuration of the Sevcon.
Here is the super special old IXXAT USB-CAN compact cable that works with the old DVT software. Cost me ~$350
I bought a Sub D9 connector and soldered the CAN High, CAN Low, and GND connections on it. You also have to solder on a jumper wire from pin 2 to pin 24 on the Sevcon for the CAN termination if this is your only controller/CAN device.
Here are some pictures of my bench top setup. I screwed down the controller, contactor, and a SS relay that I bought to switch the high-voltage on. For now I am providing the 12V power through my lab power supply, but in the final design I will use a DC-DC with the enable switch. The relay has a nice green led to indicate when 12V is applied on the input side.
You can see the SS relay here on the right
My battery cables are quite long, but I will shorten them when everything is finalized.
So far my wiring diagram seems to be correct.The first power up was successful. I got the contactor to close once I flipped the on/off switch on the handle bar and closed the SS relay. FYI I'm using a 48V coil contactor based on what I read about the Sevcon not liking 12V/24V coils, since it PWMs the contactor.
Now I have to setup the CAN interface on my computer and start talking with the Sevcon so that I can set up the initial parameters like the contactor PWM voltage. More to come soon hopefully.
