jameswalker
Afternoon all,
I have just finished piecing together my build, but the wheel does not turn (properly).
I have a fully charged battery at 66.4V. It is able to offer decent current draw, I have tested this. 20A through a high power light bulb, no problem.
I am using a Lyen controller, 12 FET 3077 MOSFET Mark II controller LYEN edition.
The motor is a BMC V4-T.
The motor is proven to be OK; I span the wheel reverse and took 3 phase voltage readings between different phases. All gave up to 4V AC reading, indicating that the motor is wired correctly and behaving itself.
The throttle in the off position reads 0.8V and rises to 3.6V fully open. The positive throttle feed is appx 4.5V.
When I open the throttle, the motor makes a high pitched whine for 1 second then cuts out (the cutout time is software controlled). Additionally, the wheel does twitch but it does not rotate.
I have read various posts where people try various permutations of phase wiring (yellow to green etc) and the associated hall sensors wiring, but nothing has worked so far.
What should I be investigating next?
Will the controller turn the wheel if there is a problem with the hall sensors / hall sensor wiring? I havent tested these at all; I assume they are OK as they are new, but no proof.
Is there something in the programming of these controllers that I am missing?
Thanks,
James
Thanks,
James
