Fitting a 100mm BBS02 in a 73mm bottom bracket, spacers & Q factor
Niner63
100 µW
France
Hi everyone
I’ve been advised, elsewhere, to fit a 100mm BBS02 into my Titus Silk Road 73mm BSA BB because of concerns that the 73mm BBS02 motor would fowl the flared chainstays 😕
If this is effectively my only option, with this frame set, will there be a noticeable difference to the Q factor ?
Are there any other options that I could implement or consider ?
TIA
nb CYC and similar motors are not within my current budget or a Grin all axle motor.
You can reduce the Q dimension of BBS02 by quite a bit if you substitute unflared cranks for the stock flared arms that come with the motor unit. They can be unicycle cranks if you want a tidy looking installation, or regular cranks with a right side spider (which won't interact with the Bafang chainring).
I would be somewhat concerned about chainline, which is already very bad on BBSxx systems and which caused the innermost 2 sprockets out of 8 or 9 to be unusable for me due to chain drop and instability. If you move the chainring outward by 13mm or more, that puts probably 3 more gears out of action.
A narrow-wide ring might help a little, and a Lekkie ring with increased offset would help a little more. But I would still expect to lose the use of several ratios (though you might not miss them so much once you have lots of help at the pedals).
I wouldn't put a mid drive on that nice a bike. There's no real benefit to it, and you stand the chance of defacing your expensive frame (or worse). Better to use a frame that's stiffer to resist the unanticipated forces, and less precious in case you crack the right side dropout from increased chain tension, or gouge the frame with a motor driven chain. The subtle advantages of a light supple pedal bike frame like that are completely lost when you add a ton of weight and motor power to it.
If you choose a frame that's a more obvious match for a mid drive, then you won't have to mess with absurd Q or unworkable chainline.
Thank you for your reply.
Ti Silk Road project has been shelved.
This Ti bike wasn’t my first choice to convert, I have an old steel gravel bike that I’d considered converting, however the eccentric BB casing prevented a Mid dive conversion. I then considered a DD 750W - 1,500W hub but I, initially, shelved that thought after being advised that dropouts would require modification to fit a torque arm, something I didn’t want to do but I’m now reconsidering and or fitting a lower W rear hub or even possibly a front hub as a last resort.
Put the torque arms on the inboard sides of the dropouts (in place of the washers normally used at the axle shoulders).
Thank you, I think I’ll start another thread about converting my gravel bike, different hub motor options, controllers etc
