I accidently reversed polarity on my Lyen 18fet controller. I don't get +5 volts on throttle or halls. All I can determine is that I get a small voltage like 1 volt in the +5 throttle when I turn the controller on.
I opened it up and this is what I can determine. It smells a bit burnt inside but I can't see much.
This capacitor in the middle looks a bit burnt but not too bad. The top of it looks fine where the K is. The other tiny capacitor on the bottom left next to the letters DG always looked like that based on looking at other lyen 18fet images. You can see the shunt here which looks fine.
You can see two blue identical things in the middle. The one with the two white wires attached looks burnt. The wires go outside the controller and you connect them for 48 volts, and disconnect them for 49-88 volts. This I assume was to run on multiple voltages, as I requested this from Lyen. At the time of reverse polarity I had the two white wires connected for 12s lipo. I disconnected these wires and ran on 18s lipo but the controller still didn't work.
Just another shot, you can see what looks to be a burnt spot on the middle capacitor. The other two huge capacitors on the right look OK, that white residue I don't think is from them burning. I saw another photo of a lyen 18fet and they had similar white stuff on them.
Just a full shot of the top incase you want to point something out to check.
Just another controller image I found for a lyen 18fet. You can see those large capacitors have white residue on them also.
