Metallover
I just got up and running with my new Vector frame, running a Cromotor, Max-E. With a crank and freewheel, but not chain yet..
I noticed maybe a slight loss of power, noticed the motor getting a little hot. It was about to hit 200F so I decided to pull off so it could cool down. I was riding pretty hard so I didn't think it was too abnormal. As I was pulling off, all of a sudden it felt like someone was applying the brakes real hard. The back wheel locked up and I drug the bike off the road.
When I looked down I noticed a little smoke, the freewheel was jammed to the side, and the powder coat was melting off my nice new frame!
What must have happend is the freewheel worked its way loose during the ride, then once it hit the frame it got jammed into it. Stripped all the threads and scraped the frame. The wheel is pretty locked up, but it will spin if you push it hard.
I haven't touched it yet, but I am worried the axle/frame may have been weakened by the heat. Softened? Brittle? All the nuts and bolts siezed? The heat was not on the wire side, so hopefully my axle has less of a chance of snapping later?
You can see the axle got super hot, the axle has the purple tint like a motorcycle's exhaust sometimes gets. I'm pretty sure my motor is fine; it never got above about 200F.
Should I be careful when I take it apart to pry off the freewheel? Might need to heat it back up so the hardware comes loose?
The axle looks kind of like this
before
before
