bike4life
- Joined
- Apr 10, 2020
- Messages
- 82
E bike Battery Charge Port Fried???? Is this normal....
What happened was while the 48v 20ah battery was plugged into the controller, the charge plug touched the controller's aluminum housing directly, and then black smoke and the burnt plug remains.....
Battery Seems Ok: tested with multi-meter.... 54 volts
Controller: Does not turn on: bike does not work:
When i plug the battery into the controller, and turn on the throttle switch, the throttle led glows up and then dies, as if the capacitors are drained... The led indicator shows a faint yellow instead of the 3 blue bars as its 54v, and then the yellow dies out in 2 seconds into black...Then it does not turn on at all.... The lcd screen is dead and the motor wont run and all that...
What should i do???? I dont think the whole controller is dead... Is the lcd screen throttle assembly dead? The battery charge port just shorted against the controller case.... What is going on here...
Also can someone give me a link to that charge port or say what it is. I dont know what they are called and will need to solder up a replacement...
