Kevin Crawford
Greetings everyone,
I've used a front hub eZee motor kit from Grin Cyclery for two years. I'm very happy with the kit, but have decided to swap my ebike conversion over to another bike. Since the new bike uses a different wheel size (700C, instead of 26") and I was also interested in trying a lighter motor, I decided to sell the eZee wheel, but keep the rest of the parts. A lot of folks seem to like the high-powered stuff, but I found that using my eZee at even 400W (with my 48V pack) was overkill.
In fact, as my battery pack started to wear out I dropped the current limit down to 5A (~250W) and even that was enough (I wouldn't want less than that, though). My experience is that the higher current just doesn't make my commute faster enough to make it worthwhile. It barely made a difference. It does make a noticeable difference in climbing, but I don't have enough of that on my routes that it's much of a problem. I like the additional speed that 48V vs. 36V provides. I'd like to ride in the 20-25 MPH range. I like to pedal while the motor is running, but I like that the motor is doing most of the work.
The new bike is a Specialized Sirrus Sport. It has an aluminum fork and rim brakes.
So, what I want to do is buy a new motor (or wheel) that will work with my eZee controller, that provides at least similar performance as my eZee motor did in the 250-350W range, but in a lighter package, so geared is preferable. It must be safely compatible with 48V. Reliability is paramount. This isn't an experiment and I'm not looking to push any limits. I need to get to work on time. I want to be able to bike in at least moderate rain without problems. And the longer the motor lasts, the better.
I was sold on buying one of the "Outrider" motors that Grin used to carry, but they're sold out now. So something like that would be a good baseline.
One name I see a lot is Bafang. http://www.szbaf.com/en/components/component/motor/fm-g02350dv.html looks like a possible candidate. What doesn't make sense to me is that there is another motor on their site that looks exactly the same and has exactly the same specs but has "250" in the name (for 250W apparently, even though it is claimed to work to 350W just like the other one). I also don't understand why some of their motors are listed as disc compatible, but not rim compatible. These motors are also about the same weight as the eZee. Might there be another suitable option besides the 2.4 kg Outrider that is considerably lighter? If all else fails I'd be OK with getting another eZee, but it just seems to be more motor than I need.
Any advice is greatly appreciated! Thank you very much!
