Filibogado
100 µW
- Joined
- Aug 19, 2011
- Messages
- 9
This is my first build so I hope I can keep the laughter down to a minimum.
After struggling through the thicket of controller wires assembling a MXUS motor without the benefit of a wiring diagram, I finally managed to get the wheel spinning. The only problem is that the front wheel is spinning backwards instead of forward. I don't think I screwed up the wiring because its working. I mounted the wheel with the wire on the left side as I sit on the saddle facing forward, Is this just a matter of removing the wheel and flipping it so the hub with the wire sticking out is one the other side? Help! Thanks.
