bandaro
EDIT: Most solved, read through for your own troubleshooting, but still getting a sudden screeching sound when making more than about 1500 watts. It's not the regular motor winding up and getting louder, any ideas what it is and how it can be fixed? Means I am always backing off when it happens, going slower... Also does it on braking.
G'day guys, been playing around on my board, swapped over from a dlux esc to dual FVT 120a recently, running dual rear motors. It's a "low" power setup, geared for 40kph (hitting 38)
I'm running the stock settings on the esc's currently, and wondering what you guys are running, hoping to cut out a bit of legwork.without load both motors will wind up fine, but sometimes one will sit there stuttering and/or screeching at me, or one will kick in earlier/later than the other. Will this be an issue with the esc-remote calibration or the esc settings?
Trying to get everything all winded in and humming nicely, so any suggestions would be great!
Random specs: Using a proto deck with included batteries compartment ('The Baseboard', looking into producing more), LED lit power button, single charge plug (can plug in a cell checker when running), 220wh, about 20km range?, trialling my printed remote housing, 90mm wheels and 3m9gt belts. Testing a few things currently in terms of motor mounts - m4 and m5 screws, different shapes and clamp methods, trying to find the most reliable way. What I have learnt so far is phillips head bolts don't cut it - use allen key heads or they don't get tight enough.
Edit: Changed title to hopefully help others in the search.
