Galileo/Newton agree-- 9/11 was an inside job!
https://youtu.be/rgI_cbx35Nc
Between 40-50 secs into this video, gives the reason for 9/11 symbols in the media before the event.
If you try to listen to the whole video without the idiotic interruptions, I think it will give a good grounding to the big picture.
This page i found, i think consolidates a lot of the material that links Freemasonry practices to the Kabbal, Babylon and ancient Egyptian beliefs.
http://in5d.com/all-about-as-above-so-below-illustrated/
Obviously don't take it all for granted, as their is a fair amount of artistic license in the material LOL.
Its put out that in the main Judaochristian values are opposed to paganism (worship microcosm/macrocosm), which
basically asserts that you are god within, that you affect the universe and it affects you. So the the occult was forced underground, it's still obvious in eastern religious practices and hidden in Christianity like with Christmas pagan celebration of winter solstice past it's peak and the sun returning from its lowest point in the sky and the 'illuminated' golden halo around Jesus.
All said I think this points to what might happen as indicated in the video above.
The 'Star of David' oa symbol 'hidden in plain sight'.
r3volved said:
Ignorance = it / what you know about it
In your case, dividing by Zero is undefined. When we try to divide by zero, things stop making sense.
Come on its not that difficult to get enough information together to not be ignorant and put this puppy to bed.
It's meant to be confusing, it's a hidden world of control.
Ignorance and confusion is what these people thrive on while pulling strings of puppets.
Revolution/counter revolution, Hidden/Revealed, Christ/Antichrist, Stocks Up/Down, Life/Death, if they are in control of it and the more they get away with the more the buzz.
E.g. the majority of the world population are religious and we are all affected by this, this fact they are using this to create conflict.
Well said on the occultic esoteric stuff. I think there's evidence of those that think they can harness spiritual power for controlling interests in this world. Just because we may not believe in it doesn't mean THEY don't. Imo that stuff isn't necessary for arguments about 911 though?
911 is so simple-
near impossible multiple collapses,
(bonus of showing the steel and concrete turning to dust in midair) :D
the ridiculous amount of omission/contradiction in official report.
Plenty to go on from there that only adds to it. But if someone does open that door, they won't use a bunch of questions or other statements to discount/disagree the idea that what happened is inconsistent with what we've been led to believe.
I think 'inside job' and ultimately have tended towards a uni or multi-national 'secret kabal' for the perp, with real physical power to direct societies and nations- like a pyramid structure with the pyscopaths hiding at the top in their little club, trickling down their goals thru the levels.
Shit, isn't that the original seal of the US fed gov- now on the back of the dollar?
People 'think' that they aren't being manipulated by spiritual and religious symbolism, unaware of the 'feelings' generated in the psyche and collective unconcious.
Going back in theological time, to its origins of Satan, this just relates to a lust for the material world.
Look how powerfully that meaning has been altered.
It may not attend to the material specifics of 9/11 but to behind the scenes to the kabbalists 9/11 was created as a symbol of change.
Do you see that it needs to be confusing, bits of truth and lies mixed together to keep your mind trapped?
It's bending a spoon again, jump outside and try to think differently, nothing more diabolical than a confused mind.
Yep players,
It's a game played out on a checkered floor of black/white duality, the ultimate, real life board game.
If it's not obvious, then more than likely LOL.
Nice! Link me some docus if you want.
Now, assuming that's true, check out this next matrix related clip that played after 'the spoon' https://www.youtube.com/watch?v=VkMU1mKdwPI I find it at least partially applicable to some of what you are referring. Think positively on it though.
Also, consider the movie 'skeleton key' and how that could relate if evil has any sort of real super-natural power. It would still require belief in it's power to impact a person.
Personally I think having 66.6 in my sig is no different/worse than ball earth having 66.6 degrees of tilt. Funny how it's measured from vertical @ 23.4 deg instead. Makes ya think tho.
As far as 911 and satanism. I feel like that comes across as exclusively christian. Why single out those that believe differently? I got no problem with any faith if it centrally follows a code of morality, and find no need to exclude even the son of the morning in the grand scheme. All things for good.
I think it refers on one level it's the clash of the christ/antichrist as it's meant but in pop religion the antichrist appears as saviour but is really not (Neo = anagram One which indicates he's not) in bible many follow the deciever, the real messiah comes later, what's a Smith?
Then I think it shows the new order matrix moves toward synthesis, re-solution, the female downward pointing triangle moves further back to cover the male triangle, :shock: :mrgreen: on another level in psychology represents the internal struggle and resolution of opposites within an adult individual.
The architect is the creator of the material/matrix.
Have to get to watch that.
Satan is Judeochristian the really meaning is Ha-Satan angel sent by God to tempt man, materialistic.
Not that much LOL 76.6 deg
I've made that mistake too. Think about it tho- 180deg is flat, and 90deg is vertical. Earths axis is currently 23.4 from vertical. Maybe if there is evil deception, it is not all known?
Oh thanx for checkin matrix clip. I thought it was interesting but didn't get that out of it at all. I could generalize my take as a kinda yingyang thing.
Yes I hope humans can admit to their duality. But I think slapping labels like satanism and thus christianity into an argument will only polarize it among a broad group. Need to look past that stuff. I don't even mean to disagree with the points you've made, just that most in this venue (and most venues except a church) will find it off-putting.
PS: That said, see how much truth you find in this mega. https://www.youtube.com/watch?v=Lfkta0IT26w
LOL, Duhhh :oops: I didn't think that one out at all, of course face palm. Wow that's amazing, wonder when the 360 deg standard was created? Wow have to ground that revelation.
Yes the Ying/Yang is the same thing, im saying all the philosophies/religions have the same basis, it would relate to all, it's all in there, that's what i feel makes this movie amazing.
Exactly exploring the origins/aspects of these and looking past them, simply to good/evil depicted as just a balance of human craving for the material, to the craving for the immaterial.
I don't think you can separate the 9/11, world events, the elite and the theological, it's all linked, the Judeochristian aspect is very powerful in this.
Wake up.....What is a Smith?
Answer Alchemy 101.
http://www.666man.net/666religionhistoryoverview.html
First time ive delved into the roots of this -
The Babalonians, back in their astrological calendar age of Taurus (the beast), founded a religion around astrology, constellations, planets, sun/moon worship and numerology.
Their numbering system was base 60, so 6 is/was a very important number to them. sex......
They founded our time standard and easy methods back then of using a stick (sun dial) to work out the angular seasonal changes between sun/earth.
They feared virtually all their gods 36, in all obviously not the sun, in total represented in the Zodiac, totalled 666.
It's just coincidental that in present day Earth's tilt is 66.6, but this needs to be a warning that in our times.
Hope this clears up many of the sociopolitical aspects behind this thread. Cheers.
Ahh, I just mentioned because our discussion was divergent from 911 imo. Thanks for the info, it's pretty cool- I don't have much of a solid opinion one way or the other, but it's difficult to go much farther back than anchient Babylonian and Sumerian cultures. Dead sea scrolls are interesting, like jubilee, jasher, enoch
Earths tilt would have to be a coincidence of course, right? Coincidences are really fun though. Have you ever looked at sacred geometry? 'Secrets in plain sight' goes into some great ones similar to what you describe. Very well done doc imo.
https://www.youtube.com/watch?v=L777RhL_Fz4
Oh wow, #2 is finally on tube, will have to watch it!
https://www.youtube.com/watch?v=OeXVnj6ygGE
You've cracked the code mate.
A sacred geometry object should link to any other, so if you say draw one it would correspond in a golden way to another.
Wondered why I obsess about triangles, I work with 3 phase a lot.
Looks like Tesla was very in tune.
I couldn't find the a good video on the 'Golden Mean' the ratio of the divine template of all life and how we are all linked to it.
Taking the next step.
https://youtu.be/SBiwLibZqfw 666, 000 views RLOL
Yeah, narrator is a little dry on my linked content. Still interesting, but not sure how you draw all those conclusions.
Interesting imo, nothing more.
I'll prob stay with coincidental facts, and pass on the chanting. :D
Can we stop off topic now? Start a thread for it? (I'm not sure anymore what 'it' is, so your call)
LOL coincidental implies there's no connection.
It's not about analysing the chant it's about listening to it and the monk having it resonate through him, it's in tune in golden math to a natural frequency, that how octaves came about from linked video.
It's how we instinctively know harmony/beauty when they are aligned with sacred geometry/ golden math.
Because we contain the blueprint, we will instinctively know the layout of creation and express it in our creations.
That's it, there's not more to say.
The thread followed a course from an event and ended up with indicating an almost unreal explanation, the only thing left is the details which I'm not really interested in but you will most likely find many will fit in the way described.
Cheers good thread, I found it really difficult because I can feel in myself a fear of falling into deeper territory.
Have a bike ride, a beer and a chillax funny movie :D
Megacycle, nothing can change because reality is defined by perception. There are too many still asleep, because they are holding onto american dreams. Imo, even after waking up we would need to find more common ground, or it will be for naught.
Etrike, that's the most concise little vid. Nobody that discounts it deserves a sustained argument. I'm watching the big chunks turn to dust in midair as they fall.
What say you to the judy wood take, discounting the possibility that just explosives/thermite were used? Personally I always had problems with conventional weapons, because the tower collapses are far different than bldg 7 and any other building demo I've ever seen. Plus john hutchinson can mimic similar material manipulation tesla-style.
I've heard about it in passing, and happened across this short clip the other day. Discount '100% proof' and 'hologram' incase you needed to be told. What do you guys think?
[youtube]AA2TaA4Gl3w[/youtube]
This led to an investigation, and although holograms don't fit imo, the issues surrounding the 'known' facts about the planes really come into question, and there appears to be more foul play. I'm guessing the pentagon footage was never doctored because the destruction would have never matched a fake plane on video. Some of the biggest problems are evident from the mainstream coverage, and evidence is given about the 'civilian' footage in the last one.
No planes theory
breaking newton's law https://www.youtube.com/watch?v=XydM49pgOkc
theory of ghost plane https://www.youtube.com/watch?v=QNXmgF2yAEc
'ball' next to tower https://www.youtube.com/watch?v=LPKq2K2dh6k
'ballplane' @ 2.19 https://www.youtube.com/watch?v=7AJXajQVu0E
no planes used https://www.youtube.com/watch?v=IL8cJWyOxWQ
september clues https://www.youtube.com/watch?v=gORu-68SHpE
Exactly, thats why we bend to bring our perception in tune.
Like a tree swaying in the wind, natural forces pull it one way and it naturally sways back and forth a little toward balance.
I'm with you, talking about common ground, I spoke with my Mother the other day and she always really looks forward to this far off, wayward son calling.
She's always there for everyone, self sacraficing, but like any women that demands respect, do wrong by her and well you know how the saying goes, got to look after Mum.
lol
So seeing as how you're going to drag John Hutchison into this...what exactly do you think you know about this guy??
I'd really like to know what you know, because I actually KNOW him. Lets see what you get right...
My old business partner and I conversed with him for a couple years while we were replicating tesla parents (last communication was ~8 years ago). I wouldn't label it a friendship...
Started communicating with him after we saw his first Daily Planet segment (discovery channel Canada) - that must have been somewhere around year 2000.
