jimmyhackers said:
i asked about termination.....screwing or soldering.....not covering them with insulating grease/gel or waterproofing.
so.....again.....which is less likely to corrode, a screwed terminal or a a soldered terminal?
tbh i think i know the answer... its soldered. As theres zero "gap" between surfaces where corrosion can form. will be less dissimilar metals aswell,
p.s. they are eig 20ah cells. copper bus bars, terminals look "brassy". the internal square nuts in the cells seem to be stainless but still corroded badly.
A ( tin, or silver) plated terminal will not corrode.
A bare copper terminal will. A bare aluminum terminal will.
A soldered terminal will corrode, given the composition of the solder, and or the flux used ( especially with some fluxxes)
I recently replaced a phase line to the winding on a motor. I crimped, then soldered, the connection, with a copper tin plated barrel then soldered Kester 60% lead into the joint.
....it burned the next day. However, given constraint, this is what I would do for a junction where I would want the least resistance. This was permanent install inside a motor case, where extreme vibration was encountered, along with the high currents. hard to get to, reliability required. No maintenance, considerations.
Cleaned with Alcohol or acetone.
A proper screw terminal takes into consideration the application environment. Will last longer, and be better. An enginoored terminal takes into account the ability to maintain, replace, takes the workers time into account, and also provides for a long lasting easily replaceable connection.
It will keep the tarnish away. I Fking promise you. I usually coat right after the phosphorous bath.
I use silver plated Panduit. All copper is plated with tin or nickel.
Usually tin, at its 19$ per poound.
DogDipstick said:
...P8A Bundy Penetrox....Also, the Bundy Penetrox is much longer lasting and hardy than an Autozone bottle of Dielectric grease. .
Plus, it is "Made in the USA", (something that Permatex "Dielectric bulb grease" is not
PENETROX™ A non-toxic 8 ounce squeeze bottle oxide inhibitor joint compound and lubricant.
A compound is an 8 oz. squeeze bottle of electrical joint compound for a proper electrical connection between metal parts such as conductors.
It is an oxide-inhibiting compound for preventing galvanic corrosion and enhancing the connection in electrical joints. It can be used in aluminum to aluminum, aluminum to copper, and aluminum to conduit applications.
It remains workable when stored in a dry environment under 100°F
https://cf-store.widencdn.net/graybar/b/0/3/b039fae6-242f-4385-a76b-7f9a453c6ef2.pdf?response-content-disposition=inline%3B%20filename%3D%2288047845-safety-data-sheet.pdf%22&response-content-type=application%2Fpdf&Expires=1646696329&Signature=P23ir3mB6wQ7NDSAswAnYU9DB-v5qnwbFFFmA3IZpS-SqBQ1f6kzMAQdF5KmQ2xsGPoOv1Vb3rFvLeKnaoFbTnSIhkPzfgusjdYdp19h46VNfA5nyjMJ4OXOCgthY-SICBt1QGnnPz7cYHPnbnmEicogoGn3XAWi7UVldFkQP7pFBZdwevBI53IQa446o70hUSkgmVc5ljoJoFfpkczX9oynbGnimnfpKl9Af2qdsN2Fn40GWkTse3JbhHD3H~OiqGF-MAcEAdITRL7xqgRWils1QKgSOfWUNRG9zDHdOU~WUjNzBatngeixt4MBmV8SJBZZPNkoutGAu1KyGDZ~jg__&Key-Pair-Id=APKAJD5XONOBVWWOA65A
https://www.graybar.com/penetrox8482-a-oxide-inhibitor-8-oz-/p/88047845
https://www.hubbell.com/burndy/en/Products/Power-Utilities/Inhibitors-Contact-Aids-Sealants-Paint/Oxide-Inhibitor/P8A/p/1907260
https://www.amazon.com/Burndy-P8A-Oxide-Inhibiting-Compounds-Container/dp/B008KLX2RY/ref=asc_df_B008KLX2RY/?tag=hyprod-20&linkCode=df0&hvadid=312431262871&hvpos=&hvnetw=g&hvrand=792433710538399879&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9007417&hvtargid=pla-523949110761&psc=1
Dammninit.
nicobie said:
I've always used grease on my car and truck batteries and have noticed it turns into a kind of crud after awhile. Any suggestions/recommendations for a brand of gel to use in its place?
Penetrox is available as a grease, or a gel. Petroleum base, or not.
You choose your battle.
PENETROX
TECHNICAL INFORMATION
PENETROX A
PENETROX A consists of a natural (petro-
leum) base vehicle in which zinc particles are
suspended. For aluminum to aluminum,
aluminum to copper applications and
aluminum conduit threads. It is not recom-
mended for use with rubber and polyethylene
insulated conductors. UL listed to 600 volts.
PENETROX A-13
PENETROX A-13 consists of a non-
petroleum base vehicle in which zinc parti-
cles are suspended. Recommended for
applications and aluminum conduit threads.
Compatible with insulating materials such as
rubber, or polyethylene. UL listed and recom-
mended for all voltages.
PENETROX E
PENETROX E consists of a non-petroleum
base vehicle in which copper granules are
suspended. Recommended for copper to
copper applications, grounding and for use
on copper conduit threads. UL listed.
Easy to apply:
1. Scratch brush the conductor surfaces until
bright and clean.
2. Immediately apply PENETROX™ to the
conductive surfaces.
3. For EXTREME HIGH VOLTAGE applications, remove all excess
PENETROX™ after installation is com-
plete.
SHELF LIFE
When stored in its original container in cool
(under 100° F) dry environment, PENE-
TROX™ oxide inhibiting compound will
remain workable and functional for (5) years
from the date marked on the container pro-
vided it is mixed per instructions prior to use
