DanGT86
Does anyone have a gates CDX belt they don't need? I need one to get measurements from. I'll take any length. Belt could also be damaged or cut.
Maybe you bought the wrong size? Maybe you accidentally cut it with a razorblade opening the box. Maybe I can give you a few dollars and save it from the trash.
I am trying to reverse engineer and machine some gates CDX carbondrive pulleys for myself. I want a belt to 3d scan and to use for testing my machined tooth profiles. Gates is super secretive about these dimensions and apparently the clearance changes depending on tooth count so I cant use a generic sprocket generator in CAD.
Also, if anyone has formulas or CAD designs for this CDX belt type they want to share that would be great too.
Thanks.
Thanks.
