Statesman
- Joined
- Aug 11, 2016
- Messages
- 14
I currently am using a Reid Cycles Urban X2, with a BBS02 750w M/D motor. It has a 9 speed Shimano gears. I have just had surgery on a knee injury, making my usual pedal assist ride, a throttle only, for the first week or so, setting the PAS to 0 and using just the variable throttle.
I assume that using throttle only, you travel thru the gears 1-9 just like as if you were peddling?, Would you burn out the motor if you just left it in say 3rd or 4th? My other question is the technique that should be used to change up and down in throttle/no pedal mode. Do you let off the throttle, change then reapply the throttle or do you just keep the throttle steady and shift?
I would assume that either way is going to place strain on the drive train/chain etc, but just wondering which method, or any other, is least damaging to the drive train
Many thanks, Chris
Many thanks, Chris
