The automatic 2 speed gears, i guess thats how the motor is connected to the gearbox normally, 2 gears on the output shaft from the motor connects to both of those gears on your gearbox? Been a slipper spur gear setup they start off in the lower gear and once rpms go over a set amount they switch to the higher which locks in until the rpms drop? From what i gather it shouldn't be too hard to run the Turnigy 200kv 63-74 motor at 100V to get 20,000rpm pretty sure its been done before and the figuring out how to adjust to 20,000rpm shift should be easier, the low amps will keep the torque down and save the controller in the process
I would prefer to run this way as that section includes a slipper clutch, hopefully keep the box alive longer
So is this box a 4speed box? and do you know the ratios of all the gears? Reverse is always useful at some stage
To run all 4 gears i guess i need
http://cgi.ebay.com/Losi-LST-XXL-Slipper-SPUR-GEAR-Transmission-LST2-/220719957891?pt=Radio_Control_Parts_Accessories&hash=item3363ef4783
http://cgi.ebay.com/Losi-LST-XXL-MACH-454-CLUTCH-BELL-Gears-LST2-427-/220733640689?pt=Radio_Control_Parts_Accessories&hash=item3364c00ff1
