agrumpinthedust
- Joined
- Mar 9, 2015
- Messages
- 3
Hello,
I have what I hope are a few relatively simple questions.
I've read that if a BLDC hub motor doesn't have hall sensors that it will need kick-starting to both get it moving and to set the direction of rotation. Is that correct?
I've heard of hall-less controllers that can sense on the phase lines and use that information in place of hall sensors Are those controllers capable of starting a hall-less motor from stopped, or does this sensing only help while the motor is already spinning?
I'm considering geared BLDC hub motors (similar to http://www.uumotor.com/store/124-2014-new-6-inch-hub-motor-geared-with-no-hall-sensors-250w.html) but I'm having trouble finding a supplier that builds both hall sensors and gears into their motors. If I have the above type of motor with gears but without hall sensors, can I get this motor started from standstill with the right controller, or are the hall sensors absolutely required?
Advice appreciated and hopefully your answers will help future readers too.
Thanks!
Thanks!
