Geared Motor from china
BenBenBen
1 W
Hello all,
Doing my research, I fell on many cheap dirt bikes available for sales, that are all equipped with a ~12kW motor with integrated 4 gears gearbox that look really the same.
At list:
LMR E-LM (sometimes called Velimotor VMX12)
https://leminirider.fr/dirt-bike-pi...ctrique-lmr-e-lm-12kw-21-18-edition-2022.html
NICOT E-Beast
https://www.nicotmoto.com/fr/products-detail-119485
BHR E-Race
https://bhr-moto.com/e-race/
The firts 2 are clearly cheap as chinese good old ICE Dirt bikes. The ones that break in two as soon as you jump more than 70cm high... . The BHR seems to be a chinese made chassis base too, but looks a lot more serious in term of equipment. But the motor unit looks exactly the same from outside. Even if they propose better figures of power. Maybe a customized version of the same initial product. Or just a better controller.
I watched Youtube videos and it looks like working pretty good for all of them. (Question, of course, is how long???)
So I digged a bit more, and found this same motor unit , on Alibaba of course, and for pretty cheap.
https://french.alibaba.com/product-detail/3000W-Electric-Motorbike-Conversion-Kit-1600462905503.html
Did enyone already tried anything with it?
I'm not a big fan of the manual gearbox on an e-bike but could be interesting for some conversions. And could save a lot of work and money spent on transmission and gearing ration problem solving...
I did my maths, alway using my YZF250 rear wheel for speed calculation, and attached what I've found.
I assumed that final is a 13/45 teeth sprocket set and I calculated the max torque using the given peak power and assuming that max torque is achieved @ 4k rpm (like the QS) and that the 6k rpm is obtained with deflux.
Torque in Nm = 9.5488 x Power (kW) / Speed (rpm)
But The values seems high. Do you think I miscalculated something?
