Forgive my ignorance - and mistrust
Without going into fundamentals of mechanics and hydrodynamics, would like to hear semi-educated opinion.
Here are 2 trolling/kayaking motors:
400W Torqeedo Ultralight 403, geared. (I understand they use PWM controller for variable speed).
360W Minn Kota Endura 30, brushed (either Max version with PWM, or an add-on 3-rd party PWM).
Or 500W Minn Kota 40, brushed, PWM.
According to Torqeedo: overall efficiency of their motor (not clear whether it's all Torqee models, or only tiny 403, or huge Cruise models), i.e. efficiency on the propeller, is 44-56% of input wattage, VS unspecified "conventional electric outboard" 30-35%, VS unspecified "trolling motor" 18-22%.
This is 2-3 times difference for "trolling motor".
I understand marketing reasons, but let's cut the noise. Will 403 really run 2-3 times longer than something like Minn 30 or 40, given same size N *wh battery and roughly same speed (less than hull speed), on the same 15ft kayak or canoe?
I understand that Torqee has designed a better propeller. Also, Minn is 6-9 lbs heavier (partly due to metal lower unit, VS plastic in Torqee). But - 3 times better?... Did they consider that modern "trolling motors" often have PWM? Or, that a trolling motor on a canoe or kayak is not immersed several feet into water (there are many kayak outfitters that custom-cut the shaft shorter).
