Baron
I have been building simple e-bikes since last winter using a 48V 1000W kit from ebay, namely this one: http://www.ebay.com/itm/48V1000W-26...-Conversion-/371289491857?hash=item5672940991
This will be the third bike I strap this kit to, however this time I want to try feeding it more voltage. This is the controller I will be using: http://www.aliexpress.com/item/Free...-s-Electric-Bicycle-Controller/499889986.html
It arrived a few days ago, I asked Leo to configure it for 72V, 30A max, 70V cutoff. Hall/phase combinations have been a pita to test. More info on the controller and wiring in the next post.
I will be using these batteries in 20S2P: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=58976
The batteries arrived last week and I have been busy balancing and testing them with my 48V kit to make sure there are no duds. So far so good, just waiting for more 4mm bullet connectors in the mail so I can wire up some harnesses.
It will be interesting to see how the 1000W motor will react to being fed ~2400 peak watts. At the minimum it will probably require beefing up the phase wires, maybe even some motor ventilation mods. But, that's the point of this build log!
