This thread has been pretty overdue: finally got around to hashing it out.
Frame
Frame is a Genesis V2100. I bought it mainly because it was cheap and had a triangle that i could put batteries in.
I don't get the wally world bike bashing. I mean I stray regularly into the 50mph zone and go offroading on this bicycle. Frame is aluminum and I have had no problems with it so far. Fork headset is kinda lousy, but for $140 shipped what more can you ask for?
Tires
Kenda 838. Amazon Prime + Cheap =)
Motor
I purchased a kit from ebay, again mainly because it was cheap. The motor that came with it was a HSB36V800W.
Pushing 6kw through the motor seems to not make it happy. Melted phase wires, blown halls and hall wires lead to phase wire replacements. The new phase and halls wires are 16 gauge magnet wire (3 strands for each phase, a single strand for the halls).
Batteries
I initially ran an 36V 3s1p 8ah that would sag to LVC almost immediately. I added another 8ah in parallel for 36V3s2p 16ah. This helped out a lot with the LVC cutoff.
Next step was to add even more SLA batteries. 48V 4s2p pack 16ah.
At this point I had a lot of weight. And decided to switch to lipo.
I started with 24s1p 5ah (5x 5000mah 5s Turnigy 20C Batteries). Later updates lead to a 24s3p (5x 5000mah 5s and 12x 4000mah 4s Turnigy 20C Batteries).
Charger
Bulk charger is a 8x 585W IBM Power Supplies with a Meanwell S-150-5V-30A as a current limiter.
Controller
Went through 2 Hua Tongs. Pushed so much wattage through them that when they did fail it was almost always unrepairable. First one died when all 3 fet banks blew (15 fets blown = not worth repairing). 2nd hua tong blew 3 times and I brought it back until one of the fets took out the low voltage section of the board.
I'm currently using a 18 mosfet greentime controller with 4110 mosfets (tentatively authentic). 100V @ 65A.
Pictures: To be updated
Or view the entire album
Currently working on
Motor Rebuild
203mm rotors
DoctorBass Torque Arms (Rear is aluminum)
BBQ sensor
Frame
Tires
Motor
Batteries
Charger
Controller
Motor Rebuild
203mm rotors
BBQ sensor
