I tried a preliminary go at undoing the brake drum with a rubber band style oil filter removal thats for general purposes. It does not come off, did the same with two small hose clamps (because non fit with just one) but its to late to wake people up hammering on it.
One thing I did notice is the video the guys gear freewheels, mine doesnt but looking at mine it does look like it comes off.
If it comes off then I will buy that ebay hd freewheel disk flange adapter. Its coming from china so who knows when it will be at my door.
This odd guy with green fingernails just grinds it down, his gear also freewheels, mine doesnt. I dont know if he knew his would come off and the ebay purchase. I would have left the drum and just drilled into the drum and put a spacer in there, just small straight pieces of scrap metal to fit inside. The metal shop would even cut them for you if I purchased off cuts :thumb:
https://www.youtube.com/watch?v=7jXPPaRMylI
I dont want to mess up the drum, a few holes on the side wont hurt nothing. Theres already 2 holes in it :lol:
Amazon sells tire and tube for $25 shipped or set of 2 tires 2 tubes for $35 shipped :thumb:
Skippo said:
For the brake, from my understanding the brake drum is screw on to the hub. If you can remove it a fly wheel disc adapter like this one will allow you to add the disc easy.
Check out this video:
https://youtu.be/yID1TMHh6iA
Here is the adapter:
https://www.ebay.com/itm/254853896427?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1AJkjOrhySSWhbemE7WyUDw66&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=254853896427&targetid=1262376589176&device=m&mktype=&googleloc=9031525&poi=&campaignid=15275224983&mkgroupid=131097072938&rlsatarget=pla-1262376589176&abcId=9300697&merchantid=112081934&gclid=CjwKCAiA24SPBhB0EiwAjBgkhmuE4tmfhg0JdackZeyM8uisn9hzJ_6AUf7wb4Tc-R2f5lgXbrqFSBoCgaMQAvD_BwE
I got it off, did not take much hammering ccw with the hose clamp on to get it off. It has lots of threads engaged, probably took 7.45 full turns to get it off. Thanks for the link, I would never have done or tried it, I would have gotten the grinder out
That ebay adapter should be sweet :thumb: tyvm skippo :thumb:
Been looking for 120mm and 140mm disc brakes, there is a lot out there, but how good is the material they use?
Just a random luck of the draw.
Will I need a different caliper or normal 160 caliper works?
Will see
Next up I dont know what shape to cut the steel plate where the bicycle crank gear will mount to. Have to keep it balanced so a circular shape, will have to cut triangles out close to the circular scribe mark then use the grinder flap disk on mark.
