tycreek
- Joined
- Feb 8, 2010
- Messages
- 102
I picked up another CL bike to host my extra ebike parts... A Giant Anthem X that weighs in at about 26lbs.
I previously had Ilia fit my BMC motor and controller to 26" wheels and a new CA. All good there!
Decided to try the LiteSkin Big Apples with this one.
I've had limited time to tinker with the new bike but managed to get the tires mounted and torque arms ready with a moment here and there this last week. The bike has been sitting upside-down for a couple weeks and can now stand on its own upside right. The tires are noticeably lower weight... though the rear wheel is sure heavy compared to the featherweight that was there. The Greenfield kickstand worked well before so I got another for this bike.
Only a small bit of grinding was needed to fit some torque arms.
I notice that the Anthem frame has considerably more tire room than the Trance did. On my trance, the fenders just barely fit. In fact the tire was just touching at the bottom so I cut out the lower section of the fender right before the bottom cross brace because with tire pressure above 30psi it would touch. I don't plan on this bike having fenders but they would certainly fit this Anthem better than the Trance.
This will probably go together slow...
I need to decide where to mount the controller and power up switches so I can start on the wires. I'm thinking low on the downtube by the peddles vs the rear seatpost location I use last. Haven't decided about lights yet ... have a MS and some extra Cree's for another lightweight headlight like I made for the Trance with maybe the DC/DC under the seat? Ah... long time off to worry about that I guess.
I'm thinking about removeing the triangle bag on my other bike and make my own smaller battery mount that will work on both bikes. The 50V Lipo has been working great and will just fit this slightly smaller frame in the right angle part of the triangle above the shock.
