Goethe's Mongoose Pinn'R + HT3525
Goethe
Gothenburg
Hi! :D
This bike I'm building for my 12 year old nephew. I will deliver it as ridable in dry condition and my brother will water and crash proof it later on. The bike is a really sweet ride! I've been enjoying my debug trips so much it's gonna be tough to give the bike away! :D
Current SPEC
Bike: Mongoose Pinn'R 2010, Small
Rim: Sun Ringle MTX 24"
Tire: Maxxis Hookworm 24"
Motor: Clyte HT3525 with halls
Controller: LYEN 12fet
Battery: 24s Headway 38140s, 77V 12Ah
BMS: 2x BMSBattery 12s 100A
Charger: BMSBattery 1200W
Cycle Analyst
Magura throttle
Dr Bass Torque arms (glued with 3M DP410)
7 speed Grip shift LHS
Left to do
Oil cool hub
Auto fuse
Speed switch
Replace some cells that have high selfdischarge
Clean up the wiring
Crank the power up a little more...
The Positive's
Super solid bike!!!
Great handling with the 24" wheels and Hookworms
Stable in high speeds
Brakes
Suspension
The Negative's
The frame is a PITA to mount stuff to. No triangle. Tubes with different geometry everywhere. Aluminum..... :wink:
Dropouts needed machining because of push thru axle and lack of flat area to glue torque arms to.
Sensorless operation. Had to convert to halls.
Blown controller.
Some nerdy detail photo's.... :wink:
Awesome! Also a great way to illustrate how a picture is worth a thousand words.
