Going around any "closed-system" battery - Use your Satiator on any battery?
Hi team,
Looks to me that an increasingly large proportion of ebike motor manufacturers are getting into the closed system business (including Bafang, shame on them). This means that all of us who have bought expensive Cycle-satiator chargers, are kind of unable to use it on most of our non-DIY batteries since the Satiator just "pushes" power and, if the battery system does not recognize a specific signal (which the Satiator won't provide), it simply won't charge the battery at all.
Looking at the Stromer battery though (https://www.stromerforum.ch/showthread.php?tid=2572&page=2) and what is behind the connecting port, looks to me that most closed-system batteries are standard batteries with a standard BMS, EXCEPT that, between the charging plug and the in/out of the BMS, they have put in place some sort of system that controls the flow of electricity between the BMS and the connecting plug. A kind of "gate keeper".
HOWEVER, If I am correct, would it technically be possible to kind of bypass this controlling system by simply welding 2 charging wires to the + and the - of the BMS directly, and creating an XLR connecting port so that we can connect the Satiator directly? This way we could charge using the Satiator by bypassing this "gate keeper", and from time to time, if needed, charger the battery using the standard Charger.
Obviously that would void the battery warranty, but between voiding a warranty and having a battery degrading 3-5 faster than normal just because it gets charged at 54.6V (for a 48V battery) rather than a softer 52V, my choise is clear.
What do you think?
Yes, but
The gatekeeper circuitry may well not be located where you think
personally I would integrate with the BMS functions.
Also ability to charge off EV stations will be coming, onboard chargers.
Going all the way to the raw cells may be better, knowing how well balanced the pack is, stopping short of the pack-voltage level where that becomes an issue.
Maybe, but if BMS is located after the controlling system, then it makes sense right?
And even if BMS and controller integrated, is there a big chance of blowing everything up by connecting Satiator directly to cells and charging only up to 80% (i.e. 52V on a 13S) and doing full charge through BMS from time to time?
Since it is my understanding that most BMS do not start the balancing cycle until one reaches 54V, I am not sure what the drawback of charging to 52V without a BMS (if then we charge to 54.6V from time to time to balance every 15-20 cycles).
Yes exactly what I'm saying
staying below the shoulder is always a good idea when charging through raw batt power leads.
Just don't be surprised if they put sensors in to lockout the bike when trying that.
