mxer said:
Fantastic read and link's, I'm a little wiser now, but no where near ready yet!!!....
Still can't get my head round parrelling the balance leads, I understand why you have to do it because some chargers only have one ballance output but i thought the whole idea of the ballance leads was to keep an eye on individual cells completly seperatly ? surley parrelling balancing leads on say 2 packs of lipo's will give you a reading of two seperate cells as one ????..............one cell could read 3.6v and another at 3.0 and would show 3.6 or would it ballance them out it'self to 3.3 ??.... Am i not making sence ? Think i need to stop reading my head is spinning,......
Yep, that is about correct. Parallel connection of 2 cells (aka + to+ and - to -) will create one cell with the capacity of both cells, and a voltage somewhere in the middle, depending on the internal resistance, the capacity and voltage differences between those cells. For example, 2 cells of the same brand, same chemistry, and same capacity (lets say 3.7V nominal 5Ah), will have voltage about in the middle, in case they were charged differently, but not to far from each other. The highest charged cell will just discharge into the lowest charged cell, until the voltages are the same. In cells of different capacity, the highest capacity cell will change the least when equaling with the smaller capacity cell.
Just imagine two buckets of water, however placed at the same height (aka "grounded" with the "black wires"). When connecting both buckets at floor level, the water levels will equal out. With two different sizes of buckets, the water will still equal out. With more water in one, the water will redistribute until equalled out.
Therefore, it makes sense to first charge the individual cells to a set full charge (for example 4.10V), and only then start connecting them in parallel. Imagine one empty bucket, and one full bucket. The full bucket will empty very fast into the empty one. In lipo words: the fully charged lipo will discharge very fast, charging the discharged lipo at the same rate. Now, most lipos can discharge fine at a certain rate, but can only be charged at a very low rate (C-rating). In order to make sure you do not excess these limits, only parallel cells with the same voltage.
Note, that the balancing thing is really a precaution to prevent overvolting, because the charger keeps monitoring the voltage at single cell level. Therefore, if you connect a thousand cells in parallel, the charger will still see only one cell (with a huge capacity), and the balancing thing will prevent all those cells from overvolting, even if one or ten or 999 are duds.
More importantly, keeping cells in the same voltage range is very important when putting them in series. Imagine a 2S pack. Total voltage should be maximally 2x 4.10V = 8.20V. If one cell is a dud (at 0.20V), and the charger is NOT balancing on individual cell level, the charger will only see both cells as one pack of maximally 8.20V. Therefore, when charging, it is possible to overcharge the non-dud cell to 8.00V, which is a recipe for disaster. If you put cells of different capacity and different charge in series without balancing, you are heading that way.
Now, you have read about people bulk charging (without balancing). Only do so AFTER you are sure your cells are well balanced.
