Hi there, does anybody know why my rear wheel goldenmotor won't turn, it can turn but extremely hard to pedal as if you are pedaling with breaks on. I'm not using it with a battery right now because I have not received it, and my regular back wheel went flat so I figure I'll just use the new goldenmotor wheel to replace it. When I initially installed this hub it also had this problem. Then after I flipped up the bike and messed around with it, it went away and it rides smoothly like a normal bike. Then just this morning I was riding it and hit a bump and boom the problem returned. When I flipped the bike upside down and messed with the derailer and stuff the friction still persist. Do yall think I have bad bald bearings inside the motor? This is a freaking brand new hub & I haven't even connected a battery to it yet! I'm extremely tired of dealing with chinese vendors now. ARRRRGHGHH This whole ebike thing is a fricking nightmare. I'm down $950. With no battery yet & I can't even ride my bike as a normal bike, & a busted hub. Life is fricking great.
I think there is a bald bearing out of place or something because I can hear something that is loose in there when i try to turn the wheel with my hand.
