I have a CA 2.3, and baserunner V3 powering a 48 volt gear hub 750 watt bafang clone. I loaded the Bafang fat G60 in the phaserunner software. In the process of trying to juice it up I have managed to lock it up.
I get a 6.1 'Max regen voltage rollback active' and a 1.3 'Current Sensor calibration' I powered down, unplugged and tried to reload default but no go.
The dashboard says the motor is drawing 27 amps but motor is not energized, wheel spins free.
I am using the android app on my phone since I do not have any windows hardware ( even though it looks like it has a few capabilities that are not on the android app.)
I have watched all the videos looking for settings and tried 'sensorless' as well. The default gave me a Kv of 9.32RPM/volt and 50 pole pairs.
My ebrakes are not wired and I am admittedly confused on the regen jazz and would like to remove it from the equation for now. The halls were moving but now. I have also double checked the CA setting and used defaults whenever I was not clear.
Thank you for your help. It is appreciated.
Tom Enlow
As I indicated it was running smooth if not fast
Tom Enlow
