dnmun
1 PW
i posted up how i built this pack from hobby king lipo packs over on lee's thread: http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=54024&p=804676#p804676
i mentioned already on the Bestechpower BMS thread http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=50207 that i had the BMS begin to overheat above about 17A and could keep it at 20A for very short period before it got hot. at 22A it will go for a short period, about a minute before it begins to go into thermal runaway and gets very hot fast so i cut back on the power and decided to hack the BMS to see if i could make it handle more current if i doubled the number of output mosfets from 3 to 6.
i also felt that the small surface mount 2512 shunt resistors were getting very hot at 20A and that heat was causing the mosfet next to them to overheat first and go into thermal runaway. so i decided to also add some more shunt resistors in parallel to help keep the shunt cool, and i also decided to bypass the shunt resistors with all the current i am taking from the additional mosfets so i put a jumper wire directly to the B- terminal and bypassed the shunt resistors.
originally there were 4 10 milliohm surface mount 2512 resistors for the shunt. 2.5mR equivalent. i added four of the 4 milliohm 2512 resistors to the top of those four and ended up with a stack with an equivalent resistance of 2.5/3.5 or .658mR for the total resistance. this is about 1/3 of the original resistance so the heat produced is about 1/3 of the original and since i am bypassing the shunt with half the current using the copper wire to the B- spot then i can get twice the current through the BMS and only make 1/3 of the original heat in the shunts.
after i added the extra three mosfets i tested the output of the D126 now and i am only able to draw 30A through my dummy load of 5 1500W electric heaters at 60V so i could not test it above 30A. maximum power was about 1700W and it decayed to about 1300W over the 8 minutes as the pack voltage dropped. not too bad for such a tiny device imo.
i discharged the 5Ah pouches at 30A initial dropping to 27A after about 8 minutes when i stopped. the mosfets had not really started getting hot by then but i could detect some warmth, but slight very slight heating, as when i was using just the 3 mosfets at 17A.
