Harvest-Ready Samsung 50E Battery Packs - 16.3kWh Total - Low Cycles - Toronto Area
skhan547
🧲 New user
Toronto
Hoping this is of interest.
I have 17x 48V ebike battery packs for sale (no case). 884 cells total, 16.3 kWh.
Procured for a Powerwall project but went a different direction.
Can use for harvesting and reconfiguration into larger 72V bike batteries, or a powerwall.
Or you can just swap the BMS and stay at 48V if you prefer (no dealing with the spot-weld cleanup).
Cells are Samsung 21700 50E, 5000mAh. 10A Continuous, 15A Burst. Each pack is 13S4P (48V nominal). All packs are barely used, cells have low cycle count (<25 cycles). They were retired due to CAN communication issues, OEM BMS still works but doesn't connect to PC for diagnostics. All pack voltages are between 44.0V and 54.0V, can still be charged via existing BMS using XT60 connectors, 5A.
Asking $150 per pack, $2.88/cell (CAD)
Make me an offer for the lot.
Located in Toronto, Canada. Local pickup only.
Sold
